Re: Farmall H PTO Shaft
Posted by Mark P. Putzke on November 03, 2013 at 07:46:36 from (207.118.129.114):
In Reply to: Farmall H PTO Shaft posted by Mark P. Putzke on November 01, 2013 at 06:25:25:
Thank you greatly for all the replies. I read most of the comments and then went to work. I pulled out the whole shaft and looked in. I saw that the shaft has a sleeve and that the shaft has splines on the far end. So, I put the tractor in gear and aimed straight feeling the shaft hit the back end and then rotated gently until I felt the splines hit the hole - went in smoothly and without trouble.
Thank you for all the help folks.
