53 Super M differential oil level.
Posted by gatorhide on November 03, 2013 at 08:44:11 from (65.36.23.110):
:idea: Howdy boys, I drained the old gear oil from my 53 Super M and replaced same with GL-I 90 wt. It easily held the 13 gallons and brought the oil level to about 3 to 4 inches from the oil fill hole. Then shortly later, discovered that I have a dripping leak at the very front seal. Maybe a drip every 12 seconds or so.
Actually evidence says that I already had a small leak there, but I guess the old fluid level was low enough that it was not really leaking anymore, maybe just seeping, so I figured it wasn't a real problem.
Anyway, is the square plug that's located in front of the clutch the full indicator ?
Should I open it up and let any possible excess oil drain out or not ?
Thanks for your help ! :?
Today's Featured Article - 12-Volt Conversions for 4-Cylinder Ford 2000 & 4000 Tractors - by Tommy Duvall. After two summers of having to park my old 1964 model 4000 gas 4 cyl. on a hill just in case the 6 volt system, for whatever reason, would not crank her, I decided to try the 12 volt conversion. After some research of convert or not, I decided to go ahead, the main reason being that this tractor was a working tractor, not a show tractor (yet). I did keep everything I replaced for the day I do want to restore her to showroom condition. ... [Read Article]
