Re: Will not start
Posted by TomH on December 06, 2000 at 16:51:50 from (205.140.32.208):
In Reply to: Will not start posted by Bill Jolley on December 06, 2000 at 11:10:49:
You say good spark at coil but weak or intermittent at plugs? Sounds like bad insulation or a short somewhere. Check everything inside the distributor (connectors,etc), sounds like something is touching (or almost touching) a ground.
Post A Followup
: Re: Re: Will not start
