Re: Scrap price for cub
Posted by Buzzman72 on November 04, 2013 at 16:59:25 from (74.133.160.172):
In Reply to: Scrap price for cub posted by Super 55 on November 04, 2013 at 12:56:27:
When you check the tractor out, pay attention to the following areas:
How's the hood/tank? Is the grille still there? If it is, loosen the screws and pull it off to see if the casting under the radiator has been welded. When they freeze up, usually the first place that cracks is just behind the lower grille "shelf."
If it's a wire mesh grille, those aren't as valuable as the "bar" grilles [either 4-bar or multiple-bars]. Distributor or magneto? Any other signs of welding on any easily-seen castings?
