Re: 400 Hydraulics
Posted by SDE on November 05, 2013 at 16:28:21 from (174.124.58.189):
In Reply to: 400 Hydraulics posted by BBK on November 05, 2013 at 09:13:12:
On top of the pump is a recessed pipe plug. It is used for priming the pump. Remove the plug and add fluid until the pump is full. Put the plug back in an hope it works. Be sure it get the plug threaded into the hole properly. I messed up the threads on mine and had to replace the pump because I could not keep it from seeping a little fluid.
SDE
