Re: 400 Hydraulics
Posted by AJB-830 on November 05, 2013 at 20:54:45 from (50.105.137.56):
In Reply to: 400 Hydraulics posted by BBK on November 05, 2013 at 09:13:12:
If removing the plug from the pump and filling it with oil doesn't work, you might try this. Remove the fill plug and apply some air pressure up to 20 lbs. This worked on my 650 when I had the control removed to fix a leak. I couldn't get it to start by just priming the pump. Someone on this forum told me about this trick. Not sure if it will work on a 400 as I think those have a vent so may not build pressure. Al
