Re: farmall 400 lp wiring diagram and Behlin ps hose diagram
Posted by Hugh McKinney on November 06, 2013 at 18:00:39 from (75.104.206.23):
In Reply to: Re: farmall 400 lp wiring diagram and Behlin ps hose diagram posted by John A. on November 06, 2013 at 05:17:32:
I think you are right about them using the same harness for gas or LP. Unlike Green Tractors, the Farmall regulator/vaporizer does not use a solenoid-actuated primer for cold starts. Plus, the fuel gauge on the LP tractor does not use an electric sending unit....ie, it should be the same harness either way. Hugh
