Re: Farmall 560 diesel cooling system
Posted by Tractordanp on November 07, 2013 at 02:39:34 from (50.137.83.148):
In Reply to: Farmall 560 diesel cooling system posted by ziemerj on November 06, 2013 at 18:59:23:
My IH 460 diesel would push out about a gallon and a half when first start then it seem to be fine I finally bit the bullet and pulled head head gasket seemed to almost rotten cleaned up block and head installed new head gasket and all is good now. But I have seen on our cat 966 loader at work the same problem and that was just pluged cores in radiator we did major flush it helped but ended up replacing radiator and that one all better now
So I would get some radiator flush from auto parts store or even walmart has it and try that first
Good luck
Ps I put off pulling head on my 460 for a year afraid of what I would find and I got lucky head and block looked as if just came from machine shop
Today's Featured Article - Experimental Tractors Article - by Danny Bowes (Dsl). Tractor technology appears to have nearly hit it's pinnacle of development. If you agreed with the subtitle, you are rather mistaken. Quite, actually. As a matter of fact, some of the technology experimented with over 40 years ago makes today's tractor technology seem absolutely stale by comparison. Experimentation, from the most complex assembly to the most simple and mundane component, is as an integral a part of any farm tractor's development ... [Read Article]
