Re: 6ft or 7ft back blade for an M?
Posted by farmallhal on November 07, 2013 at 14:20:27 from (76.2.172.103):
In Reply to: 6ft or 7ft back blade for an M? posted by BigTone on November 07, 2013 at 13:50:41:
I have a Farmall M tractor with the standard drawbar and not a 3 point hitch but have used back blades on other 3 point tractors in the past. Any M worth having around will pull a 7' blade with no problem up any hill I have been on with out difficulty. I would recommend an 8' blade to cover the tire marks as your tractor will handle a larger width blade. Those 6' and 7' blades are made for Ford 8N's and similar sized tractors. I would also get a name brand one from someone who will be there when you need replacement parts down the road. I would give considerable thought to the Woods or even a Bush Hog brand before buying some off brand make which will disappear at any time in the near future. Something $150 cheaper with free shipping is being cheapened somewhere which most likely isn't visible in the photos like gage thickness of the metal, length of welds, certification level of the welders, etc. An inexpensive item like a back blade is not where a large saving can be achieved by going cheap. Hope this helps in your decision and satisfaction level in the future, Hal.
