Re: Delco-Remy Gen 1101355
Posted by gene bender on November 07, 2013 at 15:26:55 from (207.177.56.213):
In Reply to: Re: Delco-Remy Gen 1101355 posted by Stevie Mote on November 07, 2013 at 12:43:49:
Brushes dont make any difference the third is adjustable for out-put. But yours will have three and can be adjusted by loosening the screw on the brush end and rotating that brush for Amperage out-put. If you are running the mag only need a couple amps and the hi-charge position on the sw will increase the amps more. If you are using a dist you will want about 3-4 amps as the mag doesent need any batt supply.
