Re: Confused about back blade weight
Posted by Janicholson on November 08, 2013 at 14:54:00 from (74.60.94.18):
In Reply to: Confused about back blade weight posted by BigTone on November 08, 2013 at 11:29:17:
The issue is not how much it weighs. The issue is how strong it is. A heavy (in pounds) blade with poor design and small angling latch will be torn up by the M"s power.
A light in pounds blade made with substantial pivot strength, structural material instead of mild steel, and good geometry, will be a fine performer.
Weight in and of its self is an advantage when the tractor has no down pressure.
The best option is a "leveling tire/depth gauge wheel" behind the blade that keeps it at a given depth on each cut or pass, with the hitch set to float above a certain depth. Jim
