Posted by GRAPE-DRANK on November 09, 2013 at 10:43:42 from (98.117.67.240):
In Reply to: farmall super c block posted by billie graham on November 08, 2013 at 20:08:31:
There are a ton of serial number blocks that will work. The number 251069 354898 come to mind. They could say r1 r2 or maybe r3.
There are a ton of serial numbers that are compatible, some could be from stationary power units and the like.
Blocks from Super A, C, Super C, 100, 200, 130 & 230''s will all work and be a direct fit. Measure the bore diameter to make sure you order the right sleeves.
140 and 240 blocks have a different style water pump I'm not sure if they will work.
I don't know if the early thermosiphen Super A blocks are different with their water passages, it still wouldn't matter. The head gasket was different between thermosiphen and water pump. I don't know if there is a difference in the Super A head and a Super C head. The Super A governor spring is different than the Super C. That is the only difference I have been able to find.
I have built 1 Farmall motor and it's a hybrid from 3 differnent tractors. I meticulously chose every piece, went through 3 blocks. I used a 130 block, 140 crank and cam and a Super A head with a 3 angle valve job. Good luck and maybe you should call that fella that has blocks for sale.
Today's Featured Article - When Push Comes to Shove - by Dave Patterson. When I was a “kid” (still am to a deree) about two I guess, my parents couldn’t find me one day. They were horrified (we lived by the railroad), my mother thought the worst: "He’s been run over by a train, he’s gone forever!" Where did they find me? Perched up on the seat of the tractor. I’d probably plowed about 3000 acres (in my head anyway) by the time they found me. This is where my love for tractors started and has only gotten worse in my tender 50 yrs on this “green planet”. I’m par
... [Read Article]
Latest Ad:
[More Ads]
