Re: IH 806 forward gears
Posted by DeltaRed on November 09, 2013 at 12:15:44 from (97.118.27.7):
In Reply to: IH 806 forward gears posted by mark tapey on November 09, 2013 at 07:37:08:
Yes.Pull the floor board.Then you can see the range cover.It should be pretty 'selfexplenetory' on how to remove it.Fron the side,the only fork you can see is the reverse idler.But you still need to remove the range cover.And just for your information,the speed cover is sandwiched between the steering support and the transmission.
