Re: Farmall 100 electrical problem
Posted by Janicholson on November 09, 2013 at 13:19:10 from (199.17.6.25):
In Reply to: Farmall 100 electrical problem posted by steve706 on November 09, 2013 at 07:11:35:
I go with old's comment. I would first disconnect the battery and wire brush and sand out the terminal surfaces. A test light will find the location of the failed circuit. Jim
