Re: IH 806 forward gears
Posted by pete 23 on November 09, 2013 at 13:34:11 from (74.33.75.51):
In Reply to: IH 806 forward gears posted by mark tapey on November 09, 2013 at 07:37:08:
Like others said, range cover and side cover off. I am sure you will find the high low fork laying off the shift rail. Either rail broke or set screw or cap screw came out of fork. Couple different styles went into production. Then you may need to pull rear 3rd link cover and long arm reach in over differential to grab rest of rail. If broken it probably will come out the front. But to install a new one, it is from the back. I use a still hose to guide rail over differential. Different ways to do this, what ever work.
