Re: 464 gas trouble
Posted by JimB2 on November 10, 2013 at 05:48:58 from (99.241.76.141):
In Reply to: 464 gas trouble posted by Tractordanp on November 10, 2013 at 03:17:25:
Hi Dan, I have no experience with the 464 gas model only the Diesel models but the first thing I would check is the gas flow out of the fuel tank by removing the gas line at the carb and letting it run into a bucket. If it doesn't flow the full of the gas line pipe chances are there is junk in the bottom of the gas tank restricting the outlet. I don't know if the carb has an inlet fuel filter or not. If there is good gas flow then change all 4 spark plugs.
Hope this helps
JimB
