Re: super a gauges
Posted by CNKS on November 10, 2013 at 09:03:26 from (216.144.104.128):
In Reply to: Re: super a gauges posted by mtf on November 10, 2013 at 05:30:51:
324470-336879 built in 1952. As to the water temperature gauge the factory probe was put in the intake to the radiator for a distillate/kerosene tractor so it will always read low on gas. If you modify a C123 exit pipe for the C113 it will vary a lot and usually run hot as mine does because the gauge does not work correctly on a thermosiphon system. So there is no way a temperature gauge will give an "accurate" temperature..
Today's Featured Article - Pitfalls of Tractor Engine Rebuilds - by Chris Pratt. The first pop after you have put the machine together with your own hands is exciting and pleasing. The whole experience can be marred if one moves too fast and makes too many assumptions that they can just use "as is" some parts they should be closely scrutinizing and possibly attended to. In such cases, rework makes what could have been a fun project turn into an irritant or even a nightmare. Minor Irritants To give you an example of an minor but irritating proble ... [Read Article]
