Re: super m with c-281
Posted by D Slater on November 10, 2013 at 14:43:10 from (184.14.177.214):
In Reply to: super m with c-281 posted by R dahs on November 10, 2013 at 14:26:34:
Didn't come in the tractor. Does it have a casting number above the C281? Does it have a engine serial number stamped in below the number 2 to 3 spark plug? Does it have a small plate retained by 2 bolts on the side of block near the carburetor? Maybe also find a date code on the block in the area below the spark plugs like 2*12*D or other numbers and letter.
