There is also a fuel screen on the back of the pump where the fuel line goes into the pump, it looks like a hex shaft about two inches long with a large hex plug screwed into the end of it. You might check that to see if it's clean and to make sure you've got fuel at least to there. Good Luck!
Today's Featured Article - Tractor Profile: Farmall M - by Staff. H so that mountable implements were interchaneable. The Farmall M was most popular with large-acreage row-crop farmers. It was powered by either a high-compression gas engine or a distillate version with lower compression. Options included the Lift-All hydraulic system, a belt pulley, PTO, rubber tires, starter, lights and a swinging drawbar. It could be ordered in the high-crop, wide-front or tricycle configurations. The high-crop version was called a Model MV.
... [Read Article]
Latest Ad:
[More Ads]
