Re: TD6 NO START ON DIESEL SIDE
Posted by Janicholson on November 10, 2013 at 19:53:01 from (74.60.94.18):
In Reply to: Re: TD6 NO START ON DIESEL SIDE posted by jim warehime on November 10, 2013 at 19:31:03:
Loosen the lines at the 2 injectors that do not show fuel. Run it on gas and have the diesel speed control about 1/2 open. Switch it over to diesel multiple times to rid the lines of air. Retuen it to gas operation as the engine gets near stopped to avoid having to use the starter motor each time. Jim
