Re: International 350 utility Head Gasket
Posted by The Gambler pulling team on November 11, 2013 at 07:10:12 from (76.26.229.184):
In Reply to: International 350 utility Head Gasket posted by JimmyTheFish on November 11, 2013 at 06:50:01:
I would pull the plugs and look into the plug holes after it sets overnight. If it is all dry then pull the oil pan and pressurize the cooling system and check between liner and block for antifreeze.
If antifreeze is on top of pistons it is head gasket or cracked head.
