Farmall Tractors Discussion Board
Re: three point on M
Posted by john d. on January 19, 1999 at 12:57:46:
In Reply to: three point on M posted by Ricky on January 19, 1999 at 07:25:40:
Volume should not be a problem. I run two cylinders almost that diameter and a LOT longer on a front end loader. My 3pt is operating with one 4x8 cylinder, and lifts everything I've ever hooked to it. If your pump is in good shape, the biggest limitations for you will be the condition of your rear tires and whether or not the front end will stay on the ground. I've been using a heavy duty JD 3-16 mounted plow on my M, and it isn't fun unless more weight is added to the front. I put one rear wheel weight out in front, but that really wasn't enough. The best results I've had was when I plowed with the front-end loader still attached! You'll be amazed at what the pump will lift with two cylinders that size!
Post a Followup
: Re: Re: three point on M
