Re: 1951 Farmall M Head Bolts
Posted by Brady Miller on November 12, 2013 at 05:33:52 from (98.191.195.130):
In Reply to: Re: 1951 Farmall M Head Bolts posted by Jay Craven on November 12, 2013 at 05:13:58:
third party image
When you reinstall the head, I like to start the torqueing process at 50 lbs, 75 lbs, then 110lbs.
Always start at your center in a circular motion working your way out. Also i like to spray your new head gasket with copper gasket spray on both sides as well. And remember cleanliness is the key on your head and block. I use brake parts cleaner and/or carb cleaner to remove oil.
