Re: CLICKING NOISE IN REVERSE
Posted by D Slater on November 12, 2013 at 14:56:36 from (184.14.177.214):
In Reply to: CLICKING NOISE IN REVERSE posted by S2710 on November 12, 2013 at 06:47:32:
If its the countershaft front seal. I would first double check things at the seal replacement. Make sure the seal retainer has the bearing seated to the housing and the nut is tight and pulling the countershaft to the bearing rear face. Front bearing places the shaft position in the housing. If the shaft is shifted a gear could be rubbing another gear.
