Re: International Hydro 86 with D312
Posted by Jim Naden on November 13, 2013 at 03:01:53 from (75.237.44.25):
In Reply to: International Hydro 86 with D312 posted by Nick Hawkes on November 12, 2013 at 20:33:22:
Nick Hawkes said: (quoted from post at 21:33:22 11/12/13) my problem is I move the shifter to the left and down to reverse it starts moving in reverse then stops till you hold slight pressure on the shifter to the left to get it to keep moving I have owned the tractor for three years and it just started doing this
Simple adjustment on the control valve spool will cure the reverse engagement issue.
Loosen the clamp and move the bracket on the spool to the right a little.
This post was edited by Jim Naden at 23:46:36 11/13/13.
