Re: engine sleeve removal
Posted by mkirsch on November 13, 2013 at 05:15:39 from (64.80.110.75):
In Reply to: engine sleeve removal posted by ziemerj on November 12, 2013 at 17:58:43:
I too have heard that you weld 2 or 3 beads up the side of the sleeve. It warps/shrinks the sleeve away from the block.
You don't need no $700 machine to pull sleeves, unless you're doing it for a living and you just like to spend money. More likely a pro would have a selection of steel "pucks" that they use to pull the sleeves with some threaded rod and simple cribbing.
Today's Featured Article - Storing Your Tractor - by Staff. If your tractor is going to be stored for any length of time, a few precautionary measures are helpful in preserving various parts, also in avoiding future difficulty. Store tractor under cover. If impossible to place tractor under cover, be sure to cover air stack and exhaust pipe. Drain radiator and engine block. To avoid gum content collections, drain both fuel tanks and carburetor. Leave radiator and fuel caps slightly loose to protect gaskets. Block tractor up to remove weight from tires and to keep tires from contact with moist floor. ... [Read Article]
