Re: F-20 flywheel puller
Posted by DeltaRed on November 13, 2013 at 12:46:42 from (97.118.30.56):
In Reply to: F-20 flywheel puller posted by Duanes on November 13, 2013 at 12:21:07:
I made one.Used a round chunk of 3/4" plate steel.Drilled 3 holes to match the holes on the flywheel.Took a long threaded 1" bolt.Welded a nut to the center of the plate.Bolt it down,turn the long bolt,flywheel will come off.But!,you must remove the small tapered 'pin' in the center.!
flywheel will NOT move if retaining pin is left in place.
