Re: IH 560 Brakes
Posted by Bill in IL on November 13, 2013 at 18:15:40 from (216.24.116.183):
In Reply to: IH 560 Brakes posted by Adrian Monfils on November 13, 2013 at 12:43:13:
I just went through the same thing. It's a real easy fix cause like said the brake backing plate prys out so you can put the seal in. My trouble was I was trying to separate it at the transmission housing..... You need to separate it right behind the lip of the brake backing plate. You can't see the seam where it separates most likely due to dirt accumulation but there is slots to get a chisel or pry bar on there.
