Re: Re: Re: $350 Cub - 12 volt conversion
Posted by T_Bone on December 07, 2000 at 18:30:35 from (207.254.53.35):
In Reply to: Re: Re: $350 Cub - 12 volt conversion posted by Stan on December 07, 2000 at 17:11:17:
Hi Stan , an alternator maxmium out put is at 2000rpm but will output less amps at a lower rpm. There is a cut off of amps and I think that was 650rpm at the alternator.
So if your engine is idleing at 450rpm @ a 6" diameter driven pulley then your alt. rpm is approx. 1087rpm enough for a small 7 to 10amp flow.
T_Bone
Post A Followup
: Re: Re: Re: Re: $350 Cub - 12 volt conversion
