Re: H Brake shaft oil seal
Posted by mkirsch on November 15, 2013 at 05:14:06 from (64.80.110.75):
In Reply to: H Brake shaft oil seal posted by Matt Reinders on November 14, 2013 at 07:48:51:
X1000!
Stop where you are! Do NOT attempt to pull the retainer!
Maybe you can use the trick where you drill a screw into the seal, then use a slide hammer to coax it out?
