Re: Farmall w6 head
Posted by Hendrik on November 15, 2013 at 08:01:20 from (193.30.192.187):
In Reply to: Re: Farmall w6 head posted by Janicholson on November 14, 2013 at 18:47:45:
Jim, you and many others recommend mounting valve seals. Reasons probably being less oil consumption and reduced blue smoke due to worn valve stems and valve guides.
However, does mounting valve seals not make the wear problem worse? I mean, depriving the valve stems and guides from engine oil can only increase the wear rate, can't it?
Thanks, Hendrik.
