Had a 686 with the d312 an early one that had the same engine as the 666
Great engine and great tractor it's almost the last of the farmall M which is its great grandfather. Rear wheels from an m will fit on the rear axles. This tractor has had some significant modifications from the m - much stronger - and all the kinks were worked out long ago
The 312 is in the melrose family of engines wet sleeved just like its the popular big brother 414/436/466 used in a lot of ih tractors and trucks
Make sure you have the coolant additive in it as it has the same cavitation issue as the others
Rebuild is about 2500 in parts and you basically get a new engine. A little higher than the rest as it wasn't widely used but still a great engine
Rock solid. Great hydraulics, independent PTO, power steering, torque amplifier (now called power shift) and good ergonomics. Better then some of the newer tractors . It was however consider a dated model I guess 40 years on the same design gets old but it did have many many positive improvements over time
Only issue is the wet sleeve cavatation issue but if its had the additive all its life your ok. Absent the cavitation issue its still being broken in lot of hours to go
After 30 years I no longer had a Need for it and traded it in
Today's Featured Article - Trenching With a Plow - by Staff. Introduction: This interesting information came from one of the discussion forums here at YT. We thought we should place it up front so it could be read by anyone interested in putting old iron to work. [Editor] I tried something new today, and it worked so well I thought I should post it - in case it might help someone else. I'm running 100 yards of 4" drain pipe from the gutter downspouts of our house to a pond down the hill. This should hel
... [Read Article]
Latest Ad:
[More Ads]
