Re: Update so far on fast hitch mower
Posted by 292 Ralph on November 15, 2013 at 22:17:22 from (98.22.46.232):
In Reply to: Update so far on fast hitch mower posted by Paul Shuler on November 15, 2013 at 16:02:49:
Pull the 4-bolt cover on the opposite side of the gear box .Take a piece of shafting a little smaller than the diameter of the shaft in the center of the lower pulley and drive the shaft and bearings out the other side where the 4-bolt cover is .The 4-bolt cover also has shims on the backside to control the endplay of shaft.
