Re: Tractor no start!!
Posted by Dave G on December 07, 2000 at 19:29:08 from (63.255.144.4):
In Reply to: Tractor no start!! posted by Bill Jolley on December 07, 2000 at 12:23:49:
It sounds like you need to take the systematic approach: 1) Get the ignition/valves confirmed- Make sure you get spark at #1 TDC. Since you had it all apart make sure of everything. Take the valve cover off and crank it through the 4 strokes and watch the valves and #1 piston do all its stuff. When this looks right check for a spark by holding the plug against the block. Does it spark when the piston is at TDC on the compression stroke. Also make sure both the lifter are loose and have clearance at #1 TDC (crank on and check other cylinders same way) so that you know they are closing. If you see the plug fire at #1 TDC and valves close, etc then this is good, not ignition. 2)For carb, check to see if gas is getting to carb. Disconnect line and make sure gas is flowing strong to carb. Try hand choking, cover air intake with hand while trying to start. If this doesn't work try the gas trick. Pull the plug and pour a little gas in the cylinders - be careful where you do it. I try and ask myself what would happen if some spilled gas would catch on fire. Being outside is usually good. The tractor should at least pop off and run a little. If it does you know it is a gas problem. Fix the carb, Intake gasket, etc. Good Luck - You will get it going.
Home
| Forums
Today's Featured Article -
An Old-Time Tractor Demonstration - by Kim Pratt. Sam was born in rural Kansas in 1926. His dad was a hard-working farmer and the children worked hard everyday to help ends meet. In the rural area he grew up in, the highlight of the week was Saturday when many people took a break from their work to go to town. It was on one such Saturday in the early 1940's when Sam was 16 years old that he ended up in Dennison, Kansas to watch a demonstration of a new tractor being put on by a local dealer. It was an Allis-Chalmers tractor dealership,
... [Read Article]
Latest Ad:
Variable pulley for case 1530 skid loader
[More Ads]
Copyright © 1997-2024 Yesterday's Tractor Co. All Rights Reserved. Reproduction of any part of this website, including design and content, without written permission is strictly prohibited. Trade Marks and Trade Names contained and used in this Website are those of others, and are used in this Website in a descriptive sense to refer to the products of others. Use of this Web site constitutes acceptance of our User Agreement and Privacy Policy TRADEMARK DISCLAIMER: Tradenames and Trademarks referred to within Yesterday's Tractor Co. products and within the Yesterday's Tractor Co. websites are the property of their respective trademark holders. None of these trademark holders are affiliated with Yesterday's Tractor Co., our products, or our website nor are we sponsored by them. John Deere and its logos are the registered trademarks of the John Deere Corporation. Agco, Agco Allis, White, Massey Ferguson and their logos are the registered trademarks of AGCO Corporation. Case, Case-IH, Farmall, International Harvester, New Holland and their logos are registered trademarks of CNH Global N.V. Yesterday's Tractors - Antique Tractor HeadquartersWebsite Accessibility Policy |
