Posted by Tom Fleming on November 16, 2013 at 09:43:54 from (67.20.233.75):
In Reply to: dry sleeves posted by Steve43 on November 13, 2013 at 10:59:28:
sleeves when new, should be snug, but not "tight". Also, the metal ring around each bore is also part of the whole setup for the sleeves to stay in place. Personally, I would install them as is, and make sure you have the correct head gasket with the metal rings around the cylinder holes.
I know for a fact that some wet sleeves I have installed were not sloppy, but definately not tight. When I turned the engine over prior to installing the head, they moved a bit. Those engines are still running just fine, with no issues.
it's your tractor, and your decision. Personally, I would go with it. your mileage may vary.
Today's Featured Article - Trenching With a Plow - by Staff. Introduction: This interesting information came from one of the discussion forums here at YT. We thought we should place it up front so it could be read by anyone interested in putting old iron to work. [Editor] I tried something new today, and it worked so well I thought I should post it - in case it might help someone else. I'm running 100 yards of 4" drain pipe from the gutter downspouts of our house to a pond down the hill. This should hel
... [Read Article]
Latest Ad:
[More Ads]
