Re: Janicholson...quick question
Posted by Janicholson on November 16, 2013 at 15:28:05 from (74.60.94.18):
In Reply to: Janicholson...quick question posted by BigTone on November 16, 2013 at 15:16:25:
The two most common issues are looseness in the throttle linkage Enclosed in the tube on the M and not normally a problem, and Idle mixture adjustment. The idle mixture screw is located near the mounting flange of the carb. Screwed out is lean screwed in is richer. Idle speed needs to be adjusted at the same time to get the sweetspot of slow smooth idle.
One other issue can be involved and that is distributor cam bushing wear and thus variable point gap. the bushing must hold the rotor with no radial play (not in and out). If it is a magneto, it will be rough if the timing is correct, as there is no centrifugal advance on a mag. Jim
