Re: ENGINE WILL STILL NOT RUN ON DIESEL SIDE
Posted by oldiron29 on November 17, 2013 at 04:40:07 from (74.88.13.13):
In Reply to: ENGINE WILL STILL NOT RUN ON DIESEL SIDE posted by jim warehime on November 17, 2013 at 04:25:47:
Jim, I think the other day you said you were geting no fuel to injectors. Do you have a fuel gauge to check the pressure? Are you getting a good stream at bleders? If so how is your switch over linkage? All parts moving freely and doing what they should? I had my plunger apart 4 time before I got good fuel bled. One little piece of old fuel slim in plunger valve stopped it from pumping fuel. oldiron29
