Re: TD6 NO START ON DIESEL SIDE
Posted by 101 jack on November 17, 2013 at 05:58:53 from (96.126.14.186):
In Reply to: TD6 NO START ON DIESEL SIDE posted by jim warehime on November 10, 2013 at 17:38:32:
check if gov. shaft is moving in pump. they tend to stick if not used.
