Re: Farmall M Quits
Posted by El Toro on November 17, 2013 at 07:44:22 from (96.244.7.206):
In Reply to: Farmall M Quits posted by JJ2 on November 17, 2013 at 06:53:33:
Disconnect the gas line at the carburetor and see if there's a full stream of gas from the tank. Use a clean container to catch the gas. If there's just a trickle of gas you have blockage in the tank or in the gas line.
If there's a full stream of gas from the tank pull that tube fitting at the carb where your gas line connects and look for a screen that may be plugged with crud. Hal
