Re: Farmall M Quits
Posted by rustyfarmall on November 17, 2013 at 07:55:05 from (208.126.186.41):
In Reply to: Farmall M Quits posted by JJ2 on November 17, 2013 at 06:53:33:
If it was a fuel problem, it would do some stumbling and sputtering before it died, and probably would NOT start right up again.
I would closely inspect the wiring, all electrical connections, and might even suspect the ignition switch.
I have an H that did the same thing a few times right after I bought it. I found the wire connections on the back of the ignition switch to be extremely loose. Fixed that, and it never botherd again.
