Re: ENGINE WILL STILL NOT RUN ON DIESEL SIDE
Posted by Janicholson on November 17, 2013 at 08:35:37 from (74.60.94.18):
In Reply to: ENGINE WILL STILL NOT RUN ON DIESEL SIDE posted by jim warehime on November 17, 2013 at 04:25:47:
Have you cracked the lines to bleed the system while running it on the gas side and switching over? This can allow priming of the injector pump to get the fuel to the injectors. Jim
