Re: Farmall 240 disk size
Posted by IH fan on November 17, 2013 at 08:37:00 from (174.70.169.139):
In Reply to: Farmall 240 disk size posted by Fudd on November 16, 2013 at 17:21:37:
Fudd said: (quoted from post at 20:21:37 11/16/13) What size disk will a 240 pull? Is an 8 foot about right? Thanks.
If it's a wheel or Fast Hitch disk, I'd think an 8' would work. A straight pull type could be a problem if you angle it so it's a deep cut. We had a 7' Fast Hitch for a Super C and didn't have a problem with it. A 240 has a few more ponies, so I'd think an 8' should work "under most conditions". You will need some rear weight to do it though, and if it's a Fast Hitch, you will want front weight also. If your 240 has a 3 point, the same would apply as the F-H.
This post was edited by IH fan at 08:38:35 11/17/13.
