300U axle hubs
Posted by bmagee on November 17, 2013 at 12:03:56 from (174.103.18.204):
I had to replace the axle bearings on the right side, I have since replaced both sides. I am now complete and installing the hubs. I had to actually beat the right side on with a sledge. I had greased up both hub splines and axle splines and still was a job getting on. The right side is back together and all turn good, but I don't think this is correct.
Am I doing something wrong? is there a trick to getting the hub started and back on easily?
Thanks
