Re: ENGINE WILL STILL NOT RUN ON DIESEL SIDE
Posted by jim warehime on November 17, 2013 at 16:46:37 from (174.236.225.93):
In Reply to: ENGINE WILL STILL NOT RUN ON DIESEL SIDE posted by jim warehime on November 17, 2013 at 04:25:47:
I have been running it on the gas side with the throttle half open, get a little bit of fuel at 2 of the injectors but none at the others. Haven't noticed any white smoke. Everything on the decompression/ switch over linkage seems to be working properly. When I throw the lever from gas to diesel it just dies dosent even attempt to fire. I checked all the fuel lines to injectors and they are clean,checked all fuel lines at pump,seperator and filter all are clean. I pulled the access panel and the plungers all seem to moving and operating properly. I am just not that familiar with these bosch pumps. Any more insight would be appreciated. Everything with the engine looks good and it don't appear the engine has had alot of use over the years. Thanks jim.
