Re: tube or tubeless
Posted by old on November 17, 2013 at 18:14:00 from (209.86.226.58):
In Reply to: tube or tubeless posted by RustyR on November 17, 2013 at 17:30:51:
When new that tractor would have used tube type rims and if the rims are made to fit they need tubes since a tube type rim is not the same as a tubeless rim and a tube type rim will not hold air
Today's Featured Article - Hydraulics - Cylinder Anatomy - by Curtis von Fange. Let’s make one more addition to our series on hydraulics. I’ve noticed a few questions in the comment section that could pertain to hydraulic cylinders so I thought we could take a short look at this real workhorse of the circuit. Cylinders are the reason for the hydraulic circuit. They take the fluid power delivered from the pump and magically change it into mechanical power. There are many types of cylinders that one might run across on a farm scenario. Each one could take a chapter in ... [Read Article]
