IH 424 Backfires when shut off???
Posted by TMRoper1669 on November 17, 2013 at 18:54:44 from (72.13.209.181):
IH 424 backfires when turned off. Tractor ran great the other day then died couldn"t get it started, so went through the motions and found bad points. Replaced the points, coil and set timing, now tractor runs ok, but the same but backfires when i turn it off any suggestions?
Today's Featured Article - Pitfalls of Tractor Engine Rebuilds - by Chris Pratt. The first pop after you have put the machine together with your own hands is exciting and pleasing. The whole experience can be marred if one moves too fast and makes too many assumptions that they can just use "as is" some parts they should be closely scrutinizing and possibly attended to. In such cases, rework makes what could have been a fun project turn into an irritant or even a nightmare. Minor Irritants To give you an example of an minor but irritating proble ... [Read Article]
