Re: Best farmall for plowing?
Posted by Janicholson on November 18, 2013 at 14:50:49 from (74.60.94.18):
In Reply to: Re: Best farmall for plowing? posted by BigTone on November 18, 2013 at 14:35:11:
Wood has been used to make emergency snow plows for years. They work for a while but have few followers after the first one breaks or wears to no value. Back blades operated when turned arond so they push going backwards work well (if a 2" PVC pipe is cut long ways to slip over the edge (2 cuts needed) it will keep it from digging into gravel or frozen dirt/lawns. Backwards is OK but will tweak your neck and back from looking at what you are doing in one speed.
A loader on an M with a snow bucket, or blade set at a 15* angle will push and pile snow 5 times better and 20 times more comfortably than a back blade. Chains are needed in all cases where a hill is to be mounted. Weights and filled tires are dramatically better than light rear end. Five forward speeds are better than one (reverse)
The little A tractor discussed will move snow for you easily and the chains cost 50% as much. And would allow you to keep the M for other applications. Jim
