Re: super a compression
Posted by Janicholson on November 18, 2013 at 17:24:26 from (74.60.94.18):
In Reply to: super a compression posted by mtf on November 18, 2013 at 17:12:49:
120 is just fine for compression. Change the oil to 15-40 diesel grade Rotella or Delo. With that compression, unless you are loosing coolant, leave it alone. The oil filler cap is the breather, it usually has vapor coming out. Putting the engine under load and working it will likely do wonders. Jim
