Re: super a compression
Posted by gene bender on November 18, 2013 at 18:17:20 from (207.177.56.213):
In Reply to: super a compression posted by mtf on November 18, 2013 at 17:12:49:
remove the plugs and lay them in order on the hood they are probably black i would try some new ones then check fuel mixture is there an adjustable jet on the bottom facing front of he carb if there is one there mite need to turn it in some as just maybe you are running too rich.
