Posted by johnald on November 18, 2013 at 18:27:15 from (74.240.136.32):
In Reply to: cub front pully posted by Brandon J on November 18, 2013 at 15:09:39:
heat, penetrating lube of your choice, light raps from a hammer and a puller. I have used a regular puller but it is questionable. Both times I felt I was close to breaking the pulley but luckily they came off, so it does work but you have to be careful. Clamshell style puller would be best but I don't have one. If you use a jaw puller screw a bold into the crank so you don't strip the threads. You will need the threads to tighten the pulley back to the crank. There are some youtube videos that show how to do it. To be clear the pulley is not threaded onto the crank, it is pressed on like a sleeve.
Today's Featured Article - Choosin, Mounting and Using a Bush Hog Type Mower - by Francis Robinson. Looking around at my new neighbors, most of whom are city raised and have recently acquired their first mini-farms of five to fifteen acres and also from reading questions ask at various discussion sites on the web it is frighteningly apparent that a great many guys (and a few gals) are learning by trial and error and mostly error how to use a very dangerous piece of farm equipment. It is also very apparent that these folks are getting a lot of very poor and often very dangerous advice fro
... [Read Article]
